After upgrade to 3.0 the dashboard looked a bit weird. I found out that piwik.woff is not loading
Failed to load resource: the server responded with a status of 404 (Not Found) - The file is definitely there and has the right permissions.
Looking in the console it seems that the query string is passed after a trailing slash - probably causing the 404.
i.e. --> …/plugins/Morpheus/fonts/piwik.woff/?42xrcb
Did you add this in a web.config within Piwik directory, or in your own web.config? Wondering if our web.config generator needs to be updated or whether issue is 100% not ours?
I installed Piwik inside of a Drupal website. The Drupal web.config file is what was blocking the .woff file extension. I didn’t change the web.config file within the Piwik directory.
