Piwik is working great but now we have been noticing that first piwik.php visit logging call taking 4 seconds and above but after the first visit it is taking time in milliseconds.
Why is this difference and how it can be minimized.
we are noticing this by using firfox firbug.
I am facing the same issue. First logging request taking about 5 seconds and next time 50 millisecond. Can you help how to improve this performance. I have tried by disabling the report archiving but same delay.
Is there any other scheduled task that I can disable.
and noted: [quote=“user guide”]
Alternatively, for optimal performance you may disable the Provider plugin and skip the potentially slow reverse DNS lookup.
[/quote]
