Piwik does not seem to be tracking anything.
I just installed piwik using the package center on my synology nas.
I set up the database, in which i see all the tables that piwik created.
I added the site i want to track: https://blog.mortentoudahl.dk
I installed the wp-piwik plugin, for my wordpress site (version 4.5.3) using the build plugin installer.
I entered the piwik url: https://mortentoudahl.dk/piwik
and my auth token.
But i do not see any statistics in my piwik dashboard, or from inside the piwik menu in wordpress.
If i do a view source on my wordpress site through the browser and search through the text, i do not see the word piwik.
This is the result of my test using the test script in wordpress:
`WP-Piwik 1.0.9
Mode: http
Test 1/3: global.getPiwikVersion
string(6) “2.16.1”
array(2) {
[0]=>
string(247) "HTTP/1.1 200 OK
Server: nginx
Date: Sun, 07 Aug 2016 17:53:39 GMT
Content-Type: application/json; charset=utf-8
Transfer-Encoding: chunked
Connection: keep-alive
Keep-Alive: timeout=20
Pragma:
Expires:
Cache-Control: must-revalidate
[1]=>
string(145) “https://mortentoudahl.dk/piwik/?module=API&method=API.getBulkRequest&format=json&urls[0]=method%3DAPI.getPiwikVersion%26idSite%3D1&token_auth=…”
Test 2/3: SitesManager.getSitesWithAtLeastViewAccess
array(1) {
[0]=>
array(17) {
[“idsite”]=>
string(1) “1”
[“name”]=>
string(13) “Personal blog”
[“main_url”]=>
string(29) “https://blog.mortentoudahl.dk”
[“ts_created”]=>
string(19) “2016-08-07 08:40:18”
[“ecommerce”]=>
string(1) “0”
[“sitesearch”]=>
string(1) “1”
[“sitesearch_keyword_parameters”]=>
string(0) “”
[“sitesearch_category_parameters”]=>
string(0) “”
[“timezone”]=>
string(17) “Europe/Copenhagen”
[“currency”]=>
string(3) “USD”
[“exclude_unknown_urls”]=>
string(1) “0”
[“excluded_ips”]=>
string(0) “”
[“excluded_parameters”]=>
string(0) “”
[“excluded_user_agents”]=>
string(0) “”
[“group”]=>
string(0) “”
[“type”]=>
string(7) “website”
[“keep_url_fragment”]=>
string(1) “0”
array(2) {
[0]=>
Server: nginx
Date: Sun, 07 Aug 2016 17:53:40 GMT
Pragma:
Expires:
[1]=>
string(168) “https://mortentoudahl.dk/piwik/?module=API&method=API.getBulkRequest&format=json&urls[0]=method%3DSitesManager.getSitesWithAtLeastViewAccess%26idSite%3D1&token_auth=…”
Test 3/3: SitesManager.getSitesIdFromSiteUrl
array(1) {
[0]=>
array(1) {
[“idsite”]=>
string(1) “1”
array(2) {
[0]=>
Server: nginx
Pragma:
Expires:
[1]=>
string(204) “https://mortentoudahl.dk/piwik/?module=API&method=API.getBulkRequest&format=json&urls[0]=method%3DSitesManager.getSitesIdFromSiteUrl%26idSite%3D1%26url%3Dhttps%3A%2F%2Fblog.mortentoudahl.dk&token_auth=…”
array(2) {
[“global_settings”]=>
array(58) {
[“revision”]=>
string(10) “2016052901”
[“last_settings_update”]=>
string(10) “1470559667”
[“piwik_mode”]=>
string(4) “http”
[“piwik_url”]=>
string(31) “https://mortentoudahl.dk/piwik/”
[“piwik_path”]=>
string(0) “”
[“piwik_user”]=>
string(0) “”
[“piwik_token”]=>
string(3) “set”
[“auto_site_config”]=>
string(1) “1”
[“default_date”]=>
string(9) “yesterday”
[“stats_seo”]=>
string(1) “0”
[“dashboard_widget”]=>
string(8) “disabled”
[“dashboard_chart”]=>
string(1) “0”
[“dashboard_seo”]=>
string(1) “0”
[“toolbar”]=>
string(1) “0”
[“capability_read_stats”]=>
array(5) {
[“administrator”]=>
string(1) “1”
[“editor”]=>
string(1) “0”
[“author”]=>
string(1) “0”
[“contributor”]=>
string(1) “0”
[“subscriber”]=>
string(1) “0”
[“perpost_stats”]=>
string(1) “0”
[“plugin_display_name”]=>
string(8) “WP-Piwik”
[“piwik_shortcut”]=>
string(1) “0”
[“shortcodes”]=>
string(1) “0”
[“track_mode”]=>
[“track_codeposition”]=>
string(6) “footer”
[“track_noscript”]=>
string(1) “0”
[“track_nojavascript”]=>
string(1) “0”
[“proxy_url”]=>
string(0) “”
[“track_content”]=>
[“track_search”]=>
string(1) “0”
[“track_404”]=>
string(1) “0”
[“add_post_annotations”]=>
string(1) “0”
[“add_customvars_box”]=>
string(1) “0”
[“add_download_extensions”]=>
string(0) “”
[“set_download_extensions”]=>
string(0) “”
[“disable_cookies”]=>
string(1) “0”
[“limit_cookies”]=>
string(1) “0”
[“limit_cookies_visitor”]=>
string(8) “34186669”
[“limit_cookies_session”]=>
string(4) “1800”
[“limit_cookies_referral”]=>
string(8) “15778463”
[“track_admin”]=>
string(1) “0”
[“capability_stealth”]=>
array(0) {
[“track_across”]=>
string(1) “0”
[“track_across_alias”]=>
string(1) “0”
[“track_feed”]=>
string(1) “0”
[“track_feed_addcampaign”]=>
string(1) “0”
[“track_feed_campaign”]=>
string(4) “feed”
[“track_heartbeat”]=>
string(1) “0”
[“track_user_id”]=>
[“cache”]=>
string(1) “1”
[“http_connection”]=>
string(4) “curl”
[“http_method”]=>
string(4) “post”
[“disable_timelimit”]=>
string(1) “0”
[“connection_timeout”]=>
string(1) “5”
[“disable_ssl_verify”]=>
string(1) “0”
[“piwik_useragent”]=>
string(3) “php”
[“piwik_useragent_string”]=>
[“track_datacfasync”]=>
string(1) “0”
[“track_cdnurl”]=>
string(0) “”
[“track_cdnurlssl”]=>
string(0) “”
[“force_protocol”]=>
[“update_notice”]=>
string(7) “enabled”
[“settings”]=>
array(6) {
[“name”]=>
string(0) “”
[“site_id”]=>
string(1) “1”
[“noscript_code”]=>
string(0) “”
[“tracking_code”]=>
string(0) “”
[“last_tracking_code_update”]=>
string(1) “0”
[“dashboard_revision”]=>
string(1) “0”
Looking in the tables that piwik created in the database, they are mainly empty…
What should i do?
