I’ve been trying to get an idea of how many bots and from what search engines are visiting my site.
Couldn’t find anything in the panel so a quick search brought me to this Piwik faq: How to - Analytics Platform - Matomo
There has been absoultely no difference with the recommended addtion of the following code: &rec=1&bots=1
Is there a seprate page I’m just not seeing that logs bots?
Thanks!
SR
matthieu
(Matthieu Aubry)
2
Thanks for that Matt, looked promising but it crashed my piwik installation.
Disregard, it’s a php problem. I needed to update to above 5.3 in order to install that module. I’ll create a new post. Thanks.
dali
5
And you need at least BotTracker 0.46 just released if you’re using 2.2.
Dali
brynn
6
Note that plugin only works if you’re using PHP-API tracking. Won’t work with js and/or image tracking.
