Piwik not counting downloads
Piwik is not counting my downloads. I found something in the FAQ, should be a problem with my download modul, which is also counting downloads per file.
There is the following hint in the FAQ: “If a third-party click handler returns a value, it is causing the browser to cancel other registered click handlers. Instead they should return false. Most scripts and libraries are doing it correctly, but you might have to manually edit your Javascript code to return false in onclick events.”
Do I have to change the piwik tracking code or the code of the download modul?
thx,
sebigbos
you’ll have to modify the download module to call the tracker properly
