This library is for integrating Piwik statistics into CodeIgniter PHP based web applications. I’m currently using (and improving) this library for my own CI projects.
The library retrieves stats through the Piwik API as well provides GeoIP capability with MaxMind’s GeoLiteCity database. A helper is also included for generating a piwik tracking tag based on the piwik settings defined in the piwik config file for easy setup across multiple CodeIgniter web apps.
Thank for your time and suggestion. However, When I use this url (http://www.cypherdemo.co.uk/test/piwik) it says connection refused. Error says that " file_get_contents: Connection Refused". Do you have any idea why is that? Is my hosting company blocking the connection?
