Piwik intégration with CNIL recommendation
#1
Hi!
I integrate Piwik on my website and code is like : <!-- Piwik --> <script type=“text/javascript”> var _paq = _paq || []; _pa - Pastebin.com but French CNIL recommend to modify this code like this documentation : http://www.cnil.fr/fileadmin/documents/approfondir/dossier/internet/Configuration_piwik.pdf
With this modification, Piwik follow nobody and don’t work, see my code modified : <!-- Piwik --> <script type=“text/javascript”> var _paq = _paq || []; _pa - Pastebin.com
Thanks !!!
(Matthieu Aubry) #2
I have contacted the CNIL and they will update the code from their PDF very soon. Please stay tuned and check again in a few days!
(Matthieu Aubry) #3
the CNIL has upgraded the PDF. Please check it out at http://www.cnil.fr/fileadmin/documents/approfondir/dossier/internet/Configuration_piwik.pdf
Let me know if this works for you now!
#4
Thanks matt!
Do you have connexion with CNIL, nobody answering to me from CNIL!!!
I think to be alone to respect CNIL recommendation…!!!
I modify my code, i waiting result from next days.
If i d’ont come back, it’s working and thank you so much by advance !!!
Bye!
(Matthieu Aubry) #5
Yes I have contacts with la CNIL. Let me know if you have issues as I can help you and get in touch with them.
(Matthieu Aubry) #6
Depuis Piwik 2.8.0 il est plus facile de se rendre Compliant avec le Cookie consent. Plus d’informations dans ce blog post: French CNIL recommends Piwik: the only analytics tool that does not require Cookie Consent - Analytics Platform - Matomo (nous allons le traduire en francais dans les prochaines semaines)
