I’m just getting started with piwik. I’ve uploaded the files to my shared sever and was able to get to the welcome screen at /piwik/. I pressed next, and the system check was completed with a few errors.
Tracker status:
404
GET request to piwik.php failed. Try whitelisting this URL from mod_security and HTTP Authentication.
. Also, when I press next on the bottom of the page, it brings me to a page not found.
If someone could help me get this set up I would really appreciate it.
Thanks for your response! Could you please tell me in which file I can find this line? Also, will this fix the issue of the Database Setup getting the not-found page?
My hosting provider was finally able to fix the mod_security so that part works fine. However, I can’t get past the systems check page: /piwik/?action=databaseSetup&trackerStatus=0 . I get a Page not found error. If someone can help me with this please pm me.
The error is on the second screen during installation:
Tracker status 500
GET request to piwik.php failed. Try whitelisting this URL from HTTP Authentication and disable mod_security (you may have to ask your webhost).
After making this change, restart your web server.
Mod_security is disabled. Apparently I can only whitelist IP addresses, not URLs.
Check in your server error log -> what error do you see there? maybe it’s not caused by mod_security but by some other settings on your server (if so we’d like to upgrade the FAQ and error message to tell users)
