installing the plugin causes error:
Warning
JInstaller: :Install: Can’t find Joomla XML setup file.
Please advice me.
Thanks,
Michel
Joomla: 3.8.7
VirtueMart: 3.2.14
Warning
Please advice me.
Thanks,
Michel
Joomla: 3.8.7
VirtueMart: 3.2.14
Just keep in mind, that this plugin isn’t maintained by the Matomo team, but by a third-party developer, so it is probably easier asking the developer of the plugin.
But as the Logo is the Logo of the first Piwik version, I wouldn’t be surprised if the plugin hasn’t been maintained in years.
Hi Lukas, thanks for your prompt answer. Yes I know … but Matomo lists the plugin. Anyway: does Matomo sugegst an other one or is there a description how to enable VirtueMart for Matomo ? Thanks, Michel
Thanks for the idea, I probably should one day go through the list and remove really old plugins.
I unfortunatly don’t know VirtueMart, but a quick search showed this plugin. Maybe it works better:
Lukas, thanks a lot ! Warm regards, Michel
Just a question: alatak puts the following code. It is different from yours ( Piwik / Matomo) teh rest seems to be the same.
Is it ok ?
<!-- PIWIK PLUGIN TRACKING CODE -->
<!-- Piwik -->
var _paq = _paq || [];
_paq.push(["trackPageView"]);
_paq.push(["enableLinkTracking"]); (function() {
var u="//dataminings.com/piwik/";
_paq.push(["setTrackerUrl", u+"piwik.php"]);
_paq.push(["setSiteId", "5"]);
var d=document, g=d.createElement("script"), s=d.getElementsByTagName("script")[0]; g.type="text/javascript";
g.defer=true; g.async=true; g.src=u+"piwik.js"; s.parentNode.insertBefore(g,s);
</script>
<noscript><img src="//dataminings.com/piwik/?idsite=5&rec=1" style="border:0" alt="" /></noscript>
<!-- END PIWIK TRACKING CODE -->
I think this looks like the normal Matomo tracking code.
But you can check the administration page of your matomo instance to compare it.
I checked, the codes are identical (expect using delimiter for string: instead ’ —> "). But there is no data in matomo on the server dataminings.com. BTW: Matomo works already for a simple website ( without joomla). Any idea what to check, what to do ?
Do I understand it correctly? You want to track http://dataminings.com
Because I don’t see any tracking codes on this website
No: I want track davidintheshop.com and collect data on dataminings.com
for http://bundesplatz-wasserspiel.com/ it works, i see data on dataminings.com
Okay, in this case the issue is explained really quickly:
https://davidintheshop.com/ is reachable via HTTPS and it is impossible to include non-HTTPS Javascript into a HTTPS page (as this would undermine the whole security)
So you need to setup HTTPS on dataminings.com
That would also work.
