Is there a way to install Piwik ONCE and have it track stats on all sites? It does NOT have to integrate with WHM/cPanel (though that is what we are running).
We would like to set it up so that domain.com/stats would allow you to login (perhaps with teh cpanel user/pass) and then show you stats for just that domain.
Well, I’d say you have some API coding in front of you.
For each cpanel website you would have to add a “site” in Piwik and add its js code to each of the html/php/whatever sites.
As Piwik is not working with the webserver logs thats a needed process.
And for the cpanel login you would need to update these settings to the piwik users database too.
