Could you please help me with this situation. I just installed Piwik to fresh LEMP server (OpenLogic 7[sup][/sup], MariaDB, Nginx[sup]**[/sup], PHP-FPM)
[sup])[/sup] CentOS based and hosted in Azure
[sup]**)[/sup] epel-release
MariaDB, Nginx and PHP works fine as tested with web site with simple functionality.
Piwik is currently installed to location /usr/share/nginx/html/piwik by commands:
cd /usr/share/nginx/html
wget http://builds.piwik.org/piwik.zip
unzip piwik.zip
mkdir piwik/tmp
chmod 0755 -R /usr/share/nginx/html/piwik
chown -R nginx:nginx /usr/share/nginx/html/piwik
But no matter what I do still got error message in Piwik page. I have done hours of searching with Google but no solution found yet. Error message is clear but I don’t know what to do anymore:
[size=x-small]Piwik couldn’t write to some directories (running as user ‘nginx’).
Try to Execute the following commands on your server, to allow Write access on these directories:
chmod -R 0755 /usr/share/nginx/html/piwik/tmp
chmod -R 0755 /usr/share/nginx/html/piwik/tmp/assets/
chmod -R 0755 /usr/share/nginx/html/piwik/tmp/cache/
chmod -R 0755 /usr/share/nginx/html/piwik/tmp/logs/
chmod -R 0755 /usr/share/nginx/html/piwik/tmp/tcpdf/
chmod -R 0755 /usr/share/nginx/html/piwik/tmp/templates_c/
If this doesn’t work, you can try to create the directories with your FTP software, and set the CHMOD to 0755 (or 0777 if 0755 is not enough). To do so with your FTP software, right click on the directories then click permissions.[/size]
Permissions listed and even given chmod 777 to tmp and config folder:
ls -l
drwxr-xr-x. 12 nginx nginx 4096 Apr 3 11:11 piwik
cd piwik
ls -l
-rw-r--r--. 1 nginx nginx 898 Nov 28 10:24 bower.json
-rw-r--r--. 1 nginx nginx 23922 Mar 26 01:41 CHANGELOG.md
-rw-rw-r--. 1 nginx nginx 3308 Mar 18 03:11 composer.json
-rw-rw-r--. 1 nginx nginx 85914 Mar 18 03:11 composer.lock
drwxrwxrwx. 3 nginx nginx 4096 Mar 27 01:20 config
-rwxr-xr-x. 1 nginx nginx 689 Feb 11 01:18 console
-rw-r--r--. 1 nginx nginx 505 Nov 4 08:35 CONTRIBUTING.md
drwxr-xr-x. 37 nginx nginx 4096 Mar 27 01:19 core
-rw-r--r--. 1 nginx nginx 730 Dec 28 22:20 index.php
drwxr-xr-x. 2 nginx nginx 4096 Mar 26 22:29 js
drwxr-xr-x. 2 nginx nginx 4096 Mar 26 22:29 lang
-rw-r--r--. 1 nginx nginx 7486 Nov 28 10:24 LEGALNOTICE
drwxr-xr-x. 14 nginx nginx 4096 Mar 18 03:11 libs
drwxr-xr-x. 10 nginx nginx 4096 Mar 27 01:20 misc
-rw-r--r--. 1 nginx nginx 43388 Mar 12 01:05 piwik.js
-rw-r--r--. 1 nginx nginx 2279 Dec 28 22:20 piwik.php
drwxr-xr-x. 65 nginx nginx 4096 Mar 27 01:20 plugins
-rw-r--r--. 1 nginx nginx 5100 Mar 27 01:19 README.md
-rw-r--r--. 1 nginx nginx 1052 Feb 11 01:18 SECURITY.md
drwxr-xr-x. 2 nginx nginx 4096 Mar 27 01:20 tests
drwxrwxrwx. 2 nginx nginx 4096 Apr 3 11:11 tmp
drwxr-xr-x. 16 nginx nginx 4096 Mar 27 01:20 vendor
Nginx, MariaDB and PHP-FPM installation shortly:
yum install nginx -y
systemctl start nginx
systemctl enable nginx
yum install php php-common php-fpm php-mysql -y
systemctl start php-fpm
systemctl enable php-fpm
yum install mariadb-server mariadb -y
mysql_secure_installation
mysql -u root -p
MariaDB [(none)]> CREATE DATABASE piwik;
MariaDB [(none)]> CREATE USER 'piwik'@'localhost' IDENTIFIED BY 'password_here';
MariaDB [(none)]> GRANT SELECT, INSERT, UPDATE, DELETE, CREATE, DROP, ALTER, CREATE TEMPORARY TABLES, LOCK TABLES ON piwik.* TO 'piwik'@'localhost';
systemctl restart mariadb
/etc/nginx/nginx.conf:
user nginx;
worker_processes 1;
index index.php index.html index.htm;
server {
listen 80;
server_name localhost;
root /usr/share/nginx/html;
location ~ \.php$ {
fastcgi_pass 127.0.0.1:9000;
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
include fastcgi_params;
/etc/php.ini:
cgi.fix_pathinfo=0
/etc/php-fpm.d/www.conf:
user = nginx
group = nginx
listen = 127.0.0.1:9000
And finally:
systemctl restart nginx
systemctl restart php-fpm
I will add usage of Unix sockets (listen = /var/run/php-fpm/php-fpm.sock to /etc/php-fpm.d/www.conf) when basic installation works.
