since we’ve updated to Piwik 2.4.1 icons/images are loaded very slowly. When I switch between sites it takes around 2-6 seconds until all images are loaded completely.
Are you able to reproduce this issue? ANy help?
This issue occurs on 2 Piwik installation
Okay, I’ve re-uploaded a complete Piwik installation and replace all files. Loading Visitor profile… still takes approximately 10 seconds to load.
Which memory settings directives do you need?
memory_limit 768M
Database collation uses InnoDB
realpath_cache_size 16K
realpath_cache_ttl 120
user_ini.cache_ttl 300
session.cache_expire 180
apc.cache_by_default On
apc.canonicalize On
apc.coredump_unmap Off
apc.enable_cli Off
apc.enabled On
We still haven’t reproduced this issue nor other users reported it. So we are not sure how to help you? Maybe it is a problem with your hosting provider?
