I have updated two instances of Piwik to 2.14.0. For both installs all widgets do not work anymore within my CMS. Not a single auth_token is accepted anymore. Not even those from a superuser. All I get is:
Error: You can't access this resource as it requires an 'view' access for the website id = 22.
To reproduce (with a normal user or superuser):
- Login to Piwik
- Go to API and copy/paste token
- Go to Widgets, choose one and open the direct link in a new window
- Logout of Piwik from previous tab
- Re-open widget tab and add the following param &token_auth=xxxx (your token)
Is this a known issue? I assume more people suffer this.
Fact this happens for superusers too is not right I assume. Tests with normal users had 100% view/ admin access.
