first of all: all my compliments to the developers of Piwik 2.0.2.
It is a huge step between this version and the one that has been used about an year ago.
However, heres my problem.
Although I have installed and activated GeoIP (PECL) and set up the database sync
I renamed/moved it to misc/GeoIPCity.dat and after that I’ve got that error on top of my page: WARN UserCountry[2014-01-17 19:18:58] [5a7ad] Got GeoIP error when testing PHP GeoIP location provider: /var/www/piwik/libs/MaxMindGeoIP/geoip.inc(519): Undefined offset: -16776960
And in the UI I’ve got that message:
Erreur: Votre base de données GeoIP n’est pas au bon format. Elle peut être corrompue. Assurez-vous que vous utilisez la version binaire et tentez de la remplacer avec une autre copie.
There is the information about my uncompressed file:
-rw-r–r-- 1 www-data www-data 29553210 Jan 17 14:18 GeoLiteCity.dat
