I upgraded today to piwik 1.9. I wonder why no new visits occure in the database and found many errors in the apache log:
PHP Fatal error: Class ‘Piwik_UserCountry_LocationProvider’ not found in /var/www/html-ssl/piwik/core
/Tracker/Visit.php on line 609, referer: …(a page of my website)
So what I did is to comment all lines out, which use this class in Visit.php. Now it works again, but I loose any information about where the visitor comes from.
What can I do? (I do not want to use GeoIP-extensions; the old way was okay for me as I anonymize the ips).
This is still not fixed when importing logfiles although the trac entry 3452 is closed as fixed.
[Sun Oct 28 11:01:40 2012] [error] [client XXXXXXXXX] PHP Fatal error: Class ‘Piwik_UserCountry_LocationProvider’ not found in /var/www/apps/piwik/core/Tracker/Visit.php on line 628
Is it possible that the auto updater does not replace all the files correctly? I did an update from 1.9 to 1.9.1 and now - after your hint - I downloaded latest 1.9.1 zip and did a diff of all the files and some of them differ. The update completed without errors and dashboard shows version info as 1.9.1
