piwik will track not all visitors, it will also not be tracked all targets
I experienced the same behaviour after an update to Piwik 1.9. I managed to get Piwik tracking again by activating the debug mode. In piwik.php just change
$GLOBALS[‘PIWIK_TRACKER_DEBUG’] = false;
to
$GLOBALS[‘PIWIK_TRACKER_DEBUG’] = true;
Maybe this will work for you as well …
hello, how are the causes of the settings?
I activated the debug mode because I wanted to check for any error messages in the output of the script - just to get an idea what the problem was. There was no error message at all - but I realized, that Piwik continued tracking visitors instead.
I suppose, it’s a bug …
i activated the debug mode, but piwik tracking not all, it´s the same…
after updating my piwik install to 1.9.3-b7 tracking is back to normal again, i.e. my website visitors are being counted without having PIWIK_TRACKER_DEBUG set to true.
Perhaps you should give it a try?
Good luck!
thank you,
but with 1.9.3-b5 it´s the same…
Where is a downloadlink for the 1.9.3-b7 ?
