After upgrade to 1.8.4 data not record. After I uninstalled Signup and GeoIP widgets, Piwik began recording data.
What changes should be made to the widgets that work with Piwik?
Does anyone know?
Regards,
Razvan
Does anyone know?
Regards,
Razvan
I have the same problem with signup plugin, if i disable the signup plugin, piwik recording data but if i enable the signup plugin, piwik stop recording data. Can somebody have a fix for that ?
