I just updated to Piwik 1.8.3 and now the import_logs.ps script throws this error:
Fatal error: No entry is registered for key 'config’
You can restart the import of “logfile.gz” from the point it failed by specifying --skip=73 on the command line.
It seems this error is comes from line 1040 where the script gets a response (str: {“succeeded”:0,“error”:“No entry is registered for key ‘config’”}) that it doesn’t like. But I don’t know the reason for this reasponse.
I’ve got a serious issue after updating as well. I did the manual update procedure as usual but now no data or widgets or anything will display. See attached. The visit numbers show on the All Websites page and when I go to Settings it still has all my settings saved and under Websites it still has all the websites. But I can’t view any data on any of them…
