I was sitting 5 hours today how to fix that, and I found out that this is Smarty issue, and not on all system configurations.
For example on my gentoo with php 5.3.9 everything is fine (with about >3000 idsites). On cent os with php 5.3.3. it’s not ok I have empty page (~2500 idsites).
What I found out is that Smarty in some way doesn’t handle the starting tag when list is long.
Do you know the exact problem that was causing this issue? You say “What I found out is that Smarty in some way doesn’t handle the starting tag when list is long.”
Maybe it is for special website names containing special characters? would you be able to find out exactly what was causing the issue? that would be very helpful thanks
OK so it was just a bug in smarty? I will try to create 10,000 websites and then load the page. I hope it does NOT load so I can replicate. Otherwise it will be hard to fix it
