Your construction ‘cli’ somehow breaks my piwik web interface. So i use it without slashes. And… It seems to be working!
Great thanks!
ps: sorry, that’s reply to post
Great thanks!
Fix is working for me as well, thanks for posting
works for me! … thx.
Hi everybody,
thanks a lot for the tip ! It helped me so much, with everything up to date on debian, the problem occured.
I just changed the tip to be able to use it with php-fpm/fastcgi because php_sapi_name() always returns php-fcgi
– Still on top of index.php –
if ((isset($_SERVER['_'])) && (preg_match('/archive\.sh/', $_SERVER['_']) == 1)) {
gc_disable();
I think there is several ways to do it, I chose this one…
Hope it will help fresh installs.
EDIT : to identify better the problem I updated system/php to PHP 5.5.7 (the last one on a 2nd Fedora server I have) and the problem disappeared
I have 2 servers : the new one on Debian and the old with an old Fedora. Finally, the last Fedora, on this point, is more stable …
@florent.lartet – I am curious, what version of PHP did you use before upgrading? was it less than 5.3?
because in Piwik 2.0 we removed this code that calls gc_disable() and I hope your bug was on a old version
I had (and still have if I remove the gc_disabel call) the bug on my current version which is
||/ Nom Version Architecture Description
ii mysql-server 5.5.33+dfsg-0+wh all MySQL database server (metapackage depending on the
un nginx <aucun> (aucune description n'est disponible)
ii php-apc 3.1.13-1 amd64 APC (Alternative PHP Cache) module for PHP 5
ii php5 5.4.4-14+deb7u7 all server-side, HTML-embedded scripting language (meta
ii php5-cgi 5.4.4-14+deb7u7 amd64 server-side, HTML-embedded scripting language (CGI
ii php5-fpm 5.4.4-14+deb7u7 amd64 server-side, HTML-embedded scripting language (FPM-
nginx is version: nginx/1.2.1
It’s not working with APC disabled.
The crash happens on our biggest “idsite” 3’000’000 / year
Don’t hesitate if you want more information.
Thanks for the details! I created a ticket at Segmentation fault in archiving on latest stable php · Issue #4507 · matomo-org/matomo · GitHub
