Beim Erstellen eines E-Mail-Berichtes im PDF-Format erhalte ich folgende Fehlermeldungen:
There is an error. Please report the message and full backtrace in the Piwik forums (please do a Search first as it might have been reported already!).
Warning: imagepng() [function.imagepng]: open_basedir restriction in effect. File(/tmp/jpg_RYZ0X5) is not within the allowed path(s): (/home/.sites/707/site1626/web:/home/.sites/707/site1626/tmp:/usr/share/pear) in /home/.sites/707/site1626/web/piwik/libs/tcpdf/tcpdf.php on line 7659
Backtrace →
#0 Piwik_ErrorHandler(…) called at [:]#1 imagepng(…) called at [/home/.sites/707/site1626/web/piwik/libs/tcpdf/tcpdf.php:7659]#2 TCPDF->_toPNG(…) called at [/home/.sites/707/site1626/web/piwik/libs/tcpdf/tcpdf.php:7436]#3 TCPDF->Image(…) called at [/home/.sites/707/site1626/web/piwik/core/ReportRenderer/Pdf.php:271]#4 Piwik_ReportRenderer_Pdf->paintReportTable(…) called at [/home/.sites/707/site1626/web/piwik/core/ReportRenderer/Pdf.php:205]#5 Piwik_ReportRenderer_Pdf->renderReport(…) called at [:]#6 array_walk(…) called at [/home/.sites/707/site1626/web/piwik/plugins/PDFReports/API.php:351]#7 Piwik_PDFReports_API->generateReport(…) called at [:]#8 call_user_func_array(…) called at [/home/.sites/707/site1626/web/piwik/core/API/Proxy.php:179]#9 Piwik_API_Proxy->call(…) called at [/home/.sites/707/site1626/web/piwik/core/API/Request.php:121]#10 Piwik_API_Request->process(…) called at [/home/.sites/707/site1626/web/piwik/plugins/API/Controller.php:27]#11 Piwik_API_Controller->index(…) called at [:]#12 call_user_func_array(…) called at [/home/.sites/707/site1626/web/piwik/core/FrontController.php:132]#13 Piwik_FrontController->dispatch(…) called at [/home/.sites/707/site1626/web/piwik/index.php:53]
Warning: imagepng() [function.imagepng]: Invalid filename in /home/.sites/707/site1626/web/piwik/libs/tcpdf/tcpdf.php on line 7659
Backtrace →
Warning: fopen() [function.fopen]: open_basedir restriction in effect. File(/tmp/jpg_RYZ0X5) is not within the allowed path(s): (/home/.sites/707/site1626/web:/home/.sites/707/site1626/tmp:/usr/share/pear) in /home/.sites/707/site1626/web/piwik/libs/tcpdf/tcpdf.php on line 7725
Backtrace →
#0 Piwik_ErrorHandler(…) called at [:]#1 fopen(…) called at [/home/.sites/707/site1626/web/piwik/libs/tcpdf/tcpdf.php:7725]#2 TCPDF->_parsepng(…) called at [/home/.sites/707/site1626/web/piwik/libs/tcpdf/tcpdf.php:7663]#3 TCPDF->_toPNG(…) called at [/home/.sites/707/site1626/web/piwik/libs/tcpdf/tcpdf.php:7436]#4 TCPDF->Image(…) called at [/home/.sites/707/site1626/web/piwik/core/ReportRenderer/Pdf.php:271]#5 Piwik_ReportRenderer_Pdf->paintReportTable(…) called at [/home/.sites/707/site1626/web/piwik/core/ReportRenderer/Pdf.php:205]#6 Piwik_ReportRenderer_Pdf->renderReport(…) called at [:]#7 array_walk(…) called at [/home/.sites/707/site1626/web/piwik/plugins/PDFReports/API.php:351]#8 Piwik_PDFReports_API->generateReport(…) called at [:]#9 call_user_func_array(…) called at [/home/.sites/707/site1626/web/piwik/core/API/Proxy.php:179]#10 Piwik_API_Proxy->call(…) called at [/home/.sites/707/site1626/web/piwik/core/API/Request.php:121]#11 Piwik_API_Request->process(…) called at [/home/.sites/707/site1626/web/piwik/plugins/API/Controller.php:27]#12 Piwik_API_Controller->index(…) called at [:]#13 call_user_func_array(…) called at [/home/.sites/707/site1626/web/piwik/core/FrontController.php:132]#14 Piwik_FrontController->dispatch(…) called at [/home/.sites/707/site1626/web/piwik/index.php:53]
Warning: fopen(/tmp/jpg_RYZ0X5) [function.fopen]: failed to open stream: Die Operation ist nicht erlaubt in /home/.sites/707/site1626/web/piwik/libs/tcpdf/tcpdf.php on line 7725
Backtrace →
Der Tip die beiden Ordner [cache] und [images] im Verzeichnis /piwik/libs/tcpdf manuell zu Erstellen und mit vollen Rechten (chmod 777) zu versehen hat bisher nicht geholfen.
Mit der Bitte um Hilfe - Danke!
