Hi there,
We’re actually facing a specific issue with URL detection on two different levels.
In the Action / Pages section, we’re experiencing pages that appears in double.
Here’s an example :
First case : We have pages that appear as EN and others as en.
Second case: We actually happen to have nameOfTheSection//index and nameOfTheSection//defaults.aspx appearing seperatly for sections that simply end with nameOfTheSection/
So we actually managed to figured out a way to bypass this issue using the following code,
Adding the following lines of javascript into the (tracking tag)
var lowerHref = location.href.toLowerCase();
var defaultIndex = lowerHref.indexOf(“default.aspx”);
if (defaultIndex > -1) {
_paq.push([‘setCustomUrl’, lowerHref.substring(0, defaultIndex)]);
else {
_paq.push([‘setCustomUrl’, lowerHref]);
The code is to be inserted straight before the following line :
_paq.push([‘trackPageView’]);
Example :
Url Result
goodday.ca - This website is for sale! - dating single Resources and Information. goodday.ca - This website is for sale! - dating single Resources and Information.
Finally,we’re wondering if you have any feedbacks or a better way to fix this or even better if the next release of Piwik could support this bug.
Thanks
Talk Soon,
Bassem
