Hi guys,
What is the reason i see in my ‘outgoing clicks’-report my own domains?
example:
my tracking domain is: abc.com
outgoing clicks domains:
click url’s contain:
abc.com
www.abc.com
Why is and how can i resolve this?
Greetings Tako
Hi guys,
example:
abc.com
www.abc.com
Greetings Tako
Did you setup you siteurls correctly?
yeah i think so,
I have put them under ‘manage’ --> and then field 'url’s. there is where i put all the aliases? That is correct right?
That should be correct, yes.
okay brother, thanks for taking the time to answer!
