direct.yandex.ru allows you to transfer statistics via get parameter _openstat. I have to use a crutch. Can You add this possibility in the release of piwik? I do _openstat as keywords (setCampaignKeywordKey), then decoder from base 64.
plugins/Referrers/Columns/Base.php
* @param string $string
* @return bool
protected function detectCampaignFromString($string)
foreach ($this->campaignNames as $campaignNameParameter) {
$campaignName = trim(urldecode(UrlHelper::getParameterFromQueryString($string, $campaignNameParameter)));
if (!empty($campaignName)) {
break;
if (empty($campaignName)) {
return false;
$this->typeReferrerAnalyzed = Common::REFERRER_TYPE_CAMPAIGN;
$this->nameReferrerAnalyzed = $campaignName;
foreach ($this->campaignKeywords as $campaignKeywordParameter) {
$campaignKeyword = UrlHelper::getParameterFromQueryString($string, $campaignKeywordParameter);
if (!empty($campaignKeyword)) {
$this->keywordReferrerAnalyzed = trim(urldecode($campaignKeyword));
//Декодирование опенстат от яндекса (openstat direct.yandex.ru)
if ($campaignKeywordParameter=='_openstat')$this->keywordReferrerAnalyzed=base64_decode($this->keywordReferrerAnalyzed);
break;
return !empty($this->keywordReferrerAnalyzed);
