i have a problem for getting reports in piwik from a date range about 30 days on dashboard , visitors , actions tabs. when i want to do this this error occures :
Oops… there was a problem during the request. Maybe the server had a temporary issue, or maybe you requested a report with too much data. Please try again. If this error occurs repeatedly please contact your Piwik administrator for assistance.
i did archiving with below command :
/usr/bin/php /var/www/html/piwik/console core:archive --url=http://myip/piwik/
and it resolved issue just on dashboard , and it still show that error when i want to get reports for a date range about 30 days on visitors and actions tabs.
when i set the date range to smaller ranges for example about 15 days it is ok and does not shows any error.
i have installed piwik on RHEL with php 5.3.3 and mysql 5.1 .
can anyone help me how to fix this problem.
thanks
in error logs :
PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 8208 bytes) in /var/www/html/piwik/core/DataTable.php on line 1159
I have also today same PHP Fatal error in CentOS 6.6+Nginx+php5.3+mariadb 10.0.17.
Response was 'PHP Fatal error: Allowed memory size of 1073741824 bytes exhausted (tried to allocate 32 bytes) in /var/www/piwik/core/DataTable.php on line 1154 '
I solve this by increasing value of memory_limit in /etc/php.ini to 5120M. Recommended value is 256M. I started to increase value to 512M, then to 1024M and finally to 5120M. After this Fatal error doesn’t appeared anymore.
EDIT: and also edited apc.shm_size value to 5120M in /etc/php.d/apc.ini
But I got new errors:
INFO CoreConsole[2015-04-29 16:31:03] [b4974] Archived website id = 2, period = month, 6503630 visits in last last4 months, 1617355 visits this month, Time elapsed: 30271.564s
ERROR CoreConsole[2015-04-29 16:31:03] [b4974] SQLSTATE[HY000]: General error: 2006 MySQL server has gone away
