One dashboard for daily and another for yearly
Hi all!
Is it possible to set up one dashboard that shows you daily analytics and another that shows you yearly analytics?
Currently when you switch between dashboards the date range is the same as the previous dashboard.
The goal would be to have 2 custom dashboards labelled ‘daily’ and ‘yearly’.
Thanks!
PZ
Thanks Matt. I’ll check it out now.
It’s great to see product founders getting involved in support!
