susi_333
(susi_333)
1
I try to install piwik offline to do the statistics on my local computer. Therefore I use xampp.
I have troubles installing piwik . It telle me
Piwik requires either the mysqli extension or both the PDO and pdo_mysql extensions.
But, i postet in the xampp forum and both mysqli and PDO is running. So I really dont know how to solve that.
Many thanks
sivapiwik
(sivakumar)
2
hi,
Create a test.php page with
<?php
phpinfo();
and call localhost/test.php
search for mysqli , pdo. If both are present then i don’t think you will have a problem.
If not, go the php.in file and uncomment
extension=php_mysqli.dll
extension=php_pdo.dll
now restart apache and check…
It will work.
susi_333
(susi_333)
3
sorry I dont get it done. in the test.php it tells me that mysqli and pdo is enabled.
then I tried to uncomment the extensions:
even after restarting the server i cannot install piwik. sorry. any other suggestions?
vipsoft
(vipsoft)
4
Please read http://forum.piwik.org/index.php?showtopic=1324 and apply the change re: escapeshellmd
susi_333
(susi_333)
5
problem solved. it was necessary to uncomment the escapehellcmd line. thanks for your help
