I have the latest version of PIwik installed. It is not showing referral websites. If i look at my web logs via cpanel, it does show referring websites. My other sites are directing traffic over and showing that traffic is being referred, but PIwik is not showing that it is coming in.
tloosie: Let me be clearer. If you have a single Piwik website at xyz.com, and your websites at abc.com and def.com all have tracking code that point to xyz.com, then it’s only one domain (xyz.com) to get whitelisted.
If you have Piwik accessible from all your domains (e.g., abc.com/piwik, def.com/piwik, .xyz Domain Names | Join Generation XYZ) – i.e., to get first-party cookies – then yes, there’s more domains to be whitelisted. Not really your problem on HG – they do the work of whitelisting the domains.
Arlen: I can’t see a problem from my end. Can you check the server-side error logs? And as a test, comment out the “try {” and “} catch( err ) {}” lines to see if any client-side errors appear?
