I’ve installed piwik, I setup the website, and I inserted the javascript on the page. I’m not seeing any data though. Am I missing a step here?
I also changed the date to today.
Do you see it now?
A misconfigured timezone in php.ini could explain the lag.
You should also check your server error logs and run a select on your piwik database tables.
