I’ve installed matomo using docker and completed all setup steps. Also I’ve enabled SSL in the cofig file under the path /var/lib/docker/volumes/matomo/_data/config/config.ini.php
[General]
salt = "eb1XXXXXXXXXXXXXf52f4f803ae643"
trusted_hosts[] = "cs-XXX.dev.XXX.XXX:8080"
trusted_hosts[] = "food-india-organic.myshopify.com"
force_ssl = 1
Also in my tracking code I’ve changed the url to
var u="https://cs-XXX.dev.XXX.XXX:8080/";
But when I load the website(shopify store) under the console section in my chrome browser I can see that matomo is failed to load. Am I missing any configuration?.
