why can’t I see any data for events from my segments?
When I select “All Visits” the data for events are displayed.
Regards
Pete
Regards
Pete
Does nobody have an idea?
Regards
Pete
Hi!
I suppose it depends on what segment you are using and its settings. For example an event is not connected to any url or any page. If your segment is based on an url pattern then I don’t think you will be able to see any events.
