I updated my piwik to the latest version but after updating i got this. what happened? what can i do?
it looks like some files are missing. Can you check if you maybe have a plugins/CoreHome/LoginWhitelist.php
file?
As a possible solution I’d recommend you to manually replace all files with the correct one from the latest version:
https://matomo.org/docs/update/#the-manual-three-step-update
