disabled, does not help
Quite surprising… the problem happens around http://dev.piwik.org/trac/browser/trunk/core/Tracker.php#L218
somehow, after init() it sees nothing is executed for you… I don’t know if you’re familiar with code and can debug a bit ?
Note; It needs DEBUG enabled again http://piwik.org/docs/tracking-api/reference/#toc-debugging-the-tracking-api-requests
unfortunately im not familiar with the code =( btw i reinstalled completely piwik, but doesn’t
work either, i see only the old visitors, maybe something went wrong with mysql?
Is there possibility to return to 1.8.3?
Hi All,
Great looking analytics package… I’m a new User, setup and installed everything on our dedicated server today from scratch.
Everything has gone on fine and seems to be working, apart from having no data… exactly as other people in this thread mention.
I can see that the Piwik JavaScript and PHP are getting executed and return with no errors from the server… but no data is showing up at all; zilch!
Our web site is here @ http://www.inotechne.com
// WildStyle
OK - so my issues are fixed.
Turns out there was a problem with the JavaScript code that was causing the DoNotTrack plugin to load and run, well that’s what it showed when debugging… so it was ignoring the hits.
I re-copied the code from the Websites settings and then it worked… quite strange.
Anyways… hope you others get fixed.
Thanks.
// WildStyle
I ended up just exporting all the data and doing a fresh install and everything works fine!
I think maybe the update broke the package. However piwik.php was loading fine tested on my computer as well as on a VPS in a virutal machine!
How can i export and import my Data in Piwik?
sry, i had no time.
my errorfile show that:
PHP Fatal error: Cannot redeclare geoip_country_code_by_name() in /is/htdocs/wp10927758_O8TFZII0HU/www/piwik/plugins/GeoIP/libs/geoip.inc on line 347
cdeath idea didn’t have fix.
