I’m facing a weird observation using the Piwik interface :
On the same site, using a normal user or admin I have a different response time/behavior depending on the client machine.
Actions => Pages (for a single day)
Result: 500 display/2159 (report is flat)
Time to show the whole 500 lines: 5 seconds.
If I enter at bottom search this word: publications
Results of 222 pages found is displayed in 4 seconds for all 222 lines.
Now the weird part: If I use the computer of another co-worker, same building, different floor, tested with different browser or even as a Piwik Admin, the search of the word “publications” takes forever. The message “Loading data…” stay there forever.
So since Piwik is using Ajax to search and display stuff, is it a consequence of bad hardware/configuration network ? Is it possible at all ? My first impression is that it can’t be, I’m accessing the same server from the same network (AFAIK) and the servers (apache/mysql) are mostly doing the job, not the network per se.
I even check if it was related to language interface choices but no. No influence observed.
Any hint/ideas ?
