I shifted my website to another hosting service. I am now facing problem in accessing my Piwik data.
I also updated my Username and Database etc in the config.ini.php file assuming that this will work.
But the following error is been displayed: “The PDO extension is required for this adapter but the extension is not loaded”
Also, if I re-install Piwik anew for the same blog, how can I restore my traffic data? Is there any log file that I can replace to the new Piwik installation and restore all my data?
This data is for more than one year - I cannot afford to loose it. Please help!
