I had tried out piwik a while back and then took it off my site. I just downloaded the latest version and tried to get it up and running. I had nver deleted the mysql files so when I did the install I asked for a clean install. Once done I got the error below. I don’t have a clue as to what this means or how to correct this. Can someone “talk” me through it? Thanks
Ruth
SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘name’ in ‘field list’
Backtrace:
#0 /home/medalia/www/piwik/libs/Zend/Db/Statement.php(300): Zend_Db_Statement_Pdo->_execute(Array)
#1 /home/medalia/www/piwik/libs/Zend/Db/Adapter/Abstract.php(479): Zend_Db_Statement->execute(Array)
#2 /home/medalia/www/piwik/libs/Zend/Db/Adapter/Pdo/Abstract.php(238): Zend_Db_Adapter_Abstract->query(‘SELECT iddashbo…’, Array)
#3 /home/medalia/www/piwik/core/Db/Adapter/Pdo/Mysql.php(220): Zend_Db_Adapter_Pdo_Abstract->query(‘SELECT iddashbo…’, Array)
#4 /home/medalia/www/piwik/libs/Zend/Db/Adapter/Abstract.php(736): Piwik_Db_Adapter_Pdo_Mysql->query(‘SELECT iddashbo…’, Array)
#5 /home/medalia/www/piwik/core/PluginsFunctions/Sql.php(80): Zend_Db_Adapter_Abstract->fetchAll(‘SELECT iddashbo…’, Array)
#6 /home/medalia/www/piwik/core/PluginsFunctions/Sql.php(461): Piwik_Sql::fetchAll(‘SELECT iddashbo…’, Array)
#7 /home/medalia/www/piwik/plugins/Dashboard/Dashboard.php(42): Piwik_FetchAll()
#8 /home/medalia/www/piwik/plugins/Dashboard/Dashboard.php(78): Piwik_Dashboard::getAllDashboards(‘SELECT iddashbo…’, Array)
#9 /home/medalia/www/piwik/libs/Event/Dispatcher.php(284): Piwik_Dashboard->addMenus(‘medalia’)
#10 /home/medalia/www/piwik/core/PluginsManager.php(668): Event_Dispatcher->postNotification(Object(Piwik_Event_Notification))
#11 /home/medalia/www/piwik/core/Menu/Main.php(65): Piwik_PostEvent()
#12 /home/medalia/www/piwik/core/Menu/Main.php(90): Piwik_Menu_Main->get(Array, Array)
#13 /home/medalia/www/piwik/plugins/CoreHome/Controller.php(58): Piwik_GetMenu()
#14 /home/medalia/www/piwik/plugins/CoreHome/Controller.php(92): Piwik_CoreHome_Controller->getDefaultIndexView(Object(Piwik_Event_Notification), false, false)
#15 /home/medalia/www/piwik/core/FrontController.php(138): Piwik_CoreHome_Controller->index(‘Menu.add’)
#16 /home/medalia/www/piwik/index.php(53): Piwik_FrontController->dispatch()
