I have some problems to install the piwik version 0.5.4. If I try to install the script i get errors.
debug_backtrace() has been disabled for security reasons
in '/var/kunden/webs/xxxxx/piwik/core/View.php' at the line 214
#0 Piwik_ErrorHandler(2, debug_backtrace() has been disabled for security reasons, /var/kunden/webs/xxxxx/piwik/core/View.php, 214, Array ([templateName] => languages,[viewType] => ))
#1 debug_backtrace() called at [/var/kunden/webs/xxxxx/piwik/core/View.php:214]
#2 Piwik_View::factory(languages) called at [/var/kunden/webs/xxxxx/piwik/plugins/LanguagesManager/LanguagesManager.php:52]
#3 Piwik_LanguagesManager->showLanguagesSelector(Piwik_Event_Notification Object ([_notificationName] => template_topBar,[_notificationObject] => ,[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 0))
#4 call_user_func_array(Array ([0] => Piwik_LanguagesManager Object (),[1] => showLanguagesSelector), Array ([0] => Piwik_Event_Notification Object ([_notificationName] => template_topBar,[_notificationObject] => ,[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 0))) called at [/var/kunden/webs/xxxxxx/piwik/libs/Event/Dispatcher.php:284]
#5 Event_Dispatcher->postNotification(Piwik_Event_Notification Object ([_notificationName] => template_topBar,[_notificationObject] => ,[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 0), 1, ) called at [/var/kunden/webs/web2s3220/piwik/core/PluginsManager.php:504]
#6 Piwik_PostEvent(template_topBar, ) called at [/var/kunden/webs/xxxxx/piwik/core/SmartyPlugins/function.postEvent.php:39]
#7 smarty_function_postEvent(Array ([name] => template_topBar), Piwik_Smarty Object ([template_dir] => Array ([0] => /var/kunden/webs/web2s3220/piwik/plugins,[1] => /var/kunden/webs/web2s3220/piwik/themes/default,[2] => /var/kunden/webs/web2s3220/piwik/themes),[compile_dir] => /var/kunden/webs/web2s3220/piwik/tmp/templates_c,[config_dir] => configs,[plugins_dir] => Array ([0] => /var/kunden/webs/xxxxx/piwik/core/SmartyPlugins,[1] => /var/kunden/webs/xxxxx/piwik/libs/Smarty/plugins),[debugging] => 1,[error_reporting] => 30719,[debug_tpl] => ,[debugging_ctrl] => NONE,[compile_check] => 1,[force_compile] => ,[caching] => 0,[cache_dir] => /var/kunden/webs/xxxxx/piwik/tmp/cache,[cache_lifetime] => 3600,[cache_modified_check] => ,[php_handling] => 0,[security] => ,[secure_dir] => Array (),[security_settings] => Array ([PHP_HANDLING] => ,[IF_FUNCS] => Array ([0] => array,[1] => list,[2] => isset,[3] => empty,[4] => count,[5] => sizeof,[6] => in_array,[7] => is_array,[8] => true,[9] => false,[10] => null),[INCLUDE_ANY] => ,[PHP_TAGS] => ,[MODIFIER_FUNCS] => Array ([0] => count),[ALLOW_CONSTANTS] => ,[ALLOW_SUPER_GLOBALS] => 1),[trusted_dir] => Array (),[left_delimiter] => {,[right_delimiter] => },[request_vars_order] => EGPCS,[request_use_auto_globals] => 1,[compile_id] => ,[use_sub_dirs] => ,[default_modifiers] => Array (),[default_resource_type] => file,[cache_handler_func] => ,[autoload_filters] => Array (),[config_overwrite] => 1,[config_booleanize] => 1,[config_read_hidden] => ,[config_fix_newlines] => 1,[default_template_handler_func] => ,[compiler_file] => Smarty_Compiler.class.php,[compiler_class] => Smarty_Compiler,[config_class] => Config_File,[_tpl_vars] => Array ([SCRIPT_NAME] => /piwik/index.php,[tag] => piwik=0.5.4,[piwikUrl] => http://der-opticus.co.cc/piwik/,[subTemplateToLoad] => Installation/templates/welcome.tpl,[steps] => Array ([0] => welcome,[1] => systemCheck,[2] => databaseSetup,[3] => databaseCheck,[4] => tablesCreation,[5] => generalSetup,[6] => firstWebsiteSetup,[7] => displayJavascriptCode,[8] => finished),[allStepsTitle] => Array ([0] => Installation_Welcome,[1] => Installation_SystemCheck,[2] => Installation_DatabaseSetup,[3] => Installation_DatabaseCheck,[4] => Installation_Tables,[5] => Installation_GeneralSetup,[6] => Installation_SetupWebsite,[7] => Installation_JsTag,[8] => Installation_Congratulations),[currentStepName] => welcome,[showNextStep] => 1,[currentStepId] => 0,[totalNumberOfSteps] => 9,[percentDone] => 0,[percentToDo] => 100,[nextModuleName] => systemCheck,[previousModuleName] => ,[currentModule] => ,[totalTimeGeneration] => 0.041,[totalNumberOfQueries] => 0),[_smarty_vars] => ,[_sections] => Array (),[_foreach] => Array (),[_tag_stack] => Array (),[_conf_obj] => ,[_config] => Array ([0] => Array ([vars] => Array (),[files] => Array ())),[_smarty_md5] => f8d698aea36fcbead2b9d5359ffca76f,[_version] => 2.6.25,[_inclusion_depth] => 0,[_compile_id] => ,[_smarty_debug_id] => SMARTY_DEBUG,[_smarty_debug_info] => Array ([0] => Array ([type] => template,[filename] => Installation/templates/structure.tpl,[depth] => 0)),[_cache_info] => Array (),[_file_perms] => 420,[_dir_perms] => 505,[_reg_objects] => Array (),[_plugins] => Array ([modifier] => Array ([translate] => Array ([0] => smarty_modifier_translate,[1] => Installation/templates/structure.tpl,[2] => 5,[3] => 1,[4] => 1)),[function] => Array ([postEvent] => Array ([0] => smarty_function_postEvent,[1] => Installation/templates/structure.tpl,[2] => 210,[3] => 1,[4] => 1),[url] => Array ([0] => smarty_function_url,[1] => Installation/templates/structure.tpl,[2] => 222,[3] => 1,[4] => 1)),[block] => Array (),[compiler] => Array (),[prefilter] => Array (),[postfilter] => Array (),[outputfilter] => Array ([cachebuster] => Array ([0] => smarty_outputfilter_cachebuster,[1] => ,[2] => ,[3] => 1,[4] => 1),[ajaxcdn] => Array ([0] => smarty_outputfilter_ajaxcdn,[1] => ,[2] => ,[3] => 1,[4] => 1),[trimwhitespace] => Array ([0] => smarty_outputfilter_trimwhitespace,[1] => ,[2] => ,[3] => 1,[4] => 1)),[resource] => Array (),[insert] => Array ()),[_cache_serials] => Array (),[_cache_include] => ,[_cache_including] => ,[_supers] => Array ([get] => Array (),[post] => Array (),[server] => Array ([GEOIP_COUNTRY_CODE] => IL,[GEOIP_COUNTRY_NAME] => Israel,[HTTP_AUTHORIZATION] => ,[HTTP_ACCEPT] => image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/x-shockwave-flash, application/vnd.ms-excel, application/vnd.ms-powerpoint, application/msword, application/xaml+xml, application/vnd.ms-xpsdocument, application/x-ms-xbap, application/x-ms-application, */*,[HTTP_ACCEPT_LANGUAGE] => de,[HTTP_UA_CPU] => x86,[HTTP_ACCEPT_ENCODING] => gzip, deflate,[HTTP_USER_AGENT] => Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729),[HTTP_HOST] => der-opticus.co.cc,[HTTP_CONNECTION] => Keep-Alive,[PATH] => /usr/local/bin:/usr/bin:/bin,[SERVER_SIGNATURE] => Apache/2.2.9 (Debian) PHP/5.3.1 with Suhosin-Patch Server at der-opticus.co.cc Port 80
,[SERVER_SOFTWARE] => Apache/2.2.9 (Debian) PHP/5.3.1 with Suhosin-Patch,[SERVER_NAME] => der-opticus.co.cc,[SERVER_ADDR] => 188.40.80.130,[SERVER_PORT] => 80,[REMOTE_ADDR] => xxxxx,[DOCUMENT_ROOT] => /var/kunden/webs/web2s3220/,[SERVER_ADMIN] => opticus@live.de,[SCRIPT_FILENAME] => /var/kunden/webs/xxxxx/piwik/index.php,[REMOTE_PORT] => 1412,[GATEWAY_INTERFACE] => CGI/1.1,[SERVER_PROTOCOL] => HTTP/1.1,[REQUEST_METHOD] => GET,[QUERY_STRING] => ,[REQUEST_URI] => /piwik/,[SCRIPT_NAME] => /piwik/index.php,[PHP_SELF] => /piwik/index.php,[REQUEST_TIME] => 1262004150,[argv] => Array (),[argc] => 0),[session] => Array ([Piwik_Installation] => Array ([currentStepDone] => )),[request] => Array (),[cookies] => Array (),[env] => Array ([APACHE_PID_FILE] => /var/run/apache2.pid,[APACHE_RUN_USER] => www-data,[PATH] => /usr/local/bin:/usr/bin:/bin,[PWD] => /usr/src/suhosin-0.9.29,[APACHE_RUN_GROUP] => www-data,[LANG] => C,[SHLVL] => 1,[_] => /usr/sbin/apache2)))) called at [/var/kunden/webs/xxxxx/piwik/tmp/templates_c/%%DF^DF8^DF8D327D%%structure.tpl.php:220]
#8 include(/var/kunden/webs/web2s3220/piwik/tmp/templates_c/%%DF^DF8^DF8D327D%%structure.tpl.php) called at [/var/kunden/webs/xxxx/piwik/libs/Smarty/Smarty.class.php:1283]
#9 Smarty->fetch(Installation/templates/structure.tpl) called at [/var/kunden/webs/xxxxx/piwik/core/View.php:142]
#10 Piwik_View->render() called at [/var/kunden/webs/xxxxx/piwik/plugins/Installation/View.php:52]
#11 Piwik_Installation_View->render() called at [/var/kunden/webs/xxxxx/piwik/plugins/Installation/Controller.php:68]
#12 Piwik_Installation_Controller->welcome() called at [/var/kunden/webs/web2s3220/piwik/plugins/Installation/Installation.php:62]
#13 Piwik_Installation->dispatch(Piwik_Event_Notification Object ([_notificationName] => FrontController.NoConfigurationFile,[_notificationObject] => Exception Object ([] => The configuration file /var/kunden/webs/web2s3220/piwik/config/config.ini.php has not been found.,[] => ,[] => 0,[] => /var/kunden/webs/xxxx/piwik/core/Config.php,[] => 110,[] => Array ([0] => Array ([file] => /var/kunden/webs/xxxxx/piwik/core/Piwik.php,[line] => 1580,[function] => init,[class] => Piwik_Config,[type] => ->,[args] => Array ()),[1] => Array ([file] => /var/kunden/webs/xxxx/piwik/core/FrontController.php,[line] => 202,[function] => createConfigObject,[class] => Piwik,[type] => ::,[args] => Array ()),[2] => Array ([file] => /var/kunden/webs/web2s3220/piwik/index.php,[line] => 103,[function] => init,[class] => Piwik_FrontController,[type] => ->,[args] => Array ())),[] => ),[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 0))
#14 call_user_func_array(Array ([0] => Piwik_Installation Object ([] => Piwik_Installation_Controller),[1] => dispatch), Array ([0] => Piwik_Event_Notification Object ([_notificationName] => FrontController.NoConfigurationFile,[_notificationObject] => Exception Object ([] => The configuration file /var/kunden/webs/web2s3220/piwik/config/config.ini.php has not been found.,[] => ,[] => 0,[] => /var/kunden/webs/web2s3220/piwik/core/Config.php,[] => 110,[] => Array ([0] => Array ([file] => /var/kunden/webs/web2s3220/piwik/core/Piwik.php,[line] => 1580,[function] => init,[class] => Piwik_Config,[type] => ->,[args] => Array ()),[1] => Array ([file] => /var/kunden/webs/xxxxx/piwik/core/FrontController.php,[line] => 202,[function] => createConfigObject,[class] => Piwik,[type] => ::,[args] => Array ()),[2] => Array ([file] => /var/kunden/webs/web2s3220/piwik/index.php,[line] => 103,[function] => init,[class] => Piwik_FrontController,[type] => ->,[args] => Array ())),[] => ),[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 0))) called at [/var/kunden/webs/web2s3220/piwik/libs/Event/Dispatcher.php:213]
#15 Event_Dispatcher->addObserver(Array ([0] => Piwik_Installation Object ([] => Piwik_Installation_Controller),[1] => dispatch), FrontController.NoConfigurationFile) called at [/var/kunden/webs/web2s3220/piwik/core/PluginsManager.php:362]
#16 Piwik_PluginsManager->addPluginObservers(Piwik_Installation Object ([] => Piwik_Installation_Controller)) called at [/var/kunden/webs/xxxxx/piwik/core/PluginsManager.php:248]
#17 Piwik_PluginsManager->loadPlugins() called at [/var/kunden/webs/web2s3220/piwik/core/PluginsManager.php:165]
#18 Piwik_PluginsManager->setPluginsToLoad(Array ([0] => CorePluginsAdmin,[1] => CoreAdminHome,[2] => CoreHome,[3] => API,[4] => Widgetize,[5] => LanguagesManager,[6] => Actions,[7] => Dashboard,[8] => MultiSites,[9] => Referers,[10] => UserSettings,[11] => UserCountry,[12] => VisitsSummary,[13] => VisitFrequency,[14] => VisitTime,[15] => VisitorInterest,[16] => ExampleAPI,[17] => ExamplePlugin,[18] => ExampleRssWidget,[19] => ExampleFeedburner,[20] => ExampleRssWidget,[21] => Provider,[22] => Feedback,[23] => Login,[24] => UsersManager,[25] => SitesManager,[26] => Installation)) called at [/var/kunden/webs/web2s3220/piwik/core/FrontController.php:209]
#19 Piwik_FrontController->init() called at [/var/kunden/webs/xxxx/piwik/index.php:103]
Thx for Help
