I’m new to Matomo and I’m trying to integrate page view tracking into my single-page website in React, and I haven’t managed to get it to work. I’m following the guide here Single-Page Application Tracking: Integrate - Matomo Analytics (formerly Piwik Analytics) - Developer Docs - v3
but the hash change listening function isn’t working. I have the feeling I’m making some basic error, does anyone have advice on how to do this? My code looks like this:
var _paq = window._paq || [];
_paq.push(["setDocumentTitle", document.domain + "/" + document.title]);
_paq.push(["setCookieDomain", "*.<MY_WEBSITE>"]);
_paq.push(['trackPageView']);
(function() {
var u="https://<MY_WEBSITE>";
_paq.push(['setSiteId', '<MY SITE ID>']);
g.type='text/javascript'; g.async=true; g.defer=true; g.src='//<MY_WEBSITE>/matomo.js'; s.parentNode.insertBefore(g,s);
var currentUrl = location.href;
window.addEventListener('hashchange', function() {
_paq.push(['setReferrerUrl', currentUrl]);
currentUrl = '/' + window.location.hash.substr(1);
_paq.push(['setCustomUrl', currentUrl]);
_paq.push(['setDocumentTitle', 'My New Title']);
</script>
<!-- End Matomo Code -->
I’ve pasted this before the head closing tag in index.html. I’ve seen some posts suggesting to add the following to my React router
_paq.push([‘setCustomUrl’, ‘/’ + window.location.hash.substr(1)]);
_paq.push([‘setDocumentTitle’, ‘My New Title’]);
_paq.push([‘trackPageView’]);
but it’s not clear to me how to do this. Can anyone show me an explicit example of how to do this?
Stupid question, but are you using hashes to specify the routes in react? If you aren’t changing hashes when changing pages, obviously the hashchange listener won’t work.
The easiest way is to simply integrate the code into your router and call the code inside the eventlistener everytime the user changes a route.
I managed to do this by embedding the following on each of the pages I wanted to track:
// Trigger pageview tracking on mounting of React component
componentDidMount() {
this.registerPageLoad();
// Other component mounting logic if needed
// Push pageview event to Matomo on component mount
registerPageLoad(){
_paq.push(['setCustomUrl', '/MyURL']);
_paq.push(['setDocumentTitle', 'My Document Title']);
I’m sure the integrating it into the React Router is the better way to go, but I didn’t manage it yet. If I do I will post it. Thanks again for your help Lukas.
Instead of adding the code on every component, is there any other solution? So that we can have these few lines of code at one place when a page/location change event is get triggered?
