If I’m going to use the On-Premise, can I add value more than 90 days in config/config.ini.php?
[MultiChannelConversionAttribution]
available_days_prior_to_conversion = 7,30,60,90
Can you recommend reliable hosting for On-Premise setup?
How about cloud hosting with business plan, can I query “Multi channel conversion attribution” report using API with more than 90 days or configure the config/config.ini.php?
Thanks!
