I updated to Piwik 1.9 successfully without any errors.
Now I wanted to enable GeoIP and installed successfully the package libapache2-mod-geoip, configured it like in the FAQ (How to - Analytics Platform - Matomo ) and restarted Apache. In phpinfo() is the GeoIP module successfully loaded.
But if I open the Geolocation tab there is written:
GeoIP (HTTP Server Module) - Not installed
It seems to be a bug? How could I enable it?
ts77
(Thomas Seifert)
October 18, 2012, 7:22am
#2
Did you download and install the relevant datafiles from Maxmind?
This is odd… The tab should say ‘GeoIP (Apache)’ not ‘GeoIP (HTTP Server Module)’.
Can you tell me what the output of apache_get_modules() is?
Also, can you see if $_SERVER[‘GEOIP_ADDR’] and $_SERVER[‘GEOIP_COUNTRY_CODE’] are set?
No, I don’t want to use such a commercial service.
That’s NULL as ouput.
Output:
[GEOIP_COUNTRY_CODE] => DE
[GEOIP_COUNTRY_NAME] => Germany
Try replacing plugins/UserCountry/LocationProvider/GeoIp/ServerBased.php with this file http://dev.piwik.org/trac/browser/trunk/plugins/UserCountry/LocationProvider/GeoIp/ServerBased.php?format=txt
Are things working now?
wit
October 20, 2012, 12:18pm
#7
[quote=capedfuzz]
Are things working now?[/quote]
Not working - but GeoIP (HTTP Server Module) says “broken” now instead of “not installed”…
any further ideas?
Okay this shows now in green text color under “GeoIP (HTTP Server Module)”: Installed
But If I hit the link in the yellow box ("According to this provider, your current location is: ") besides this I get just:
Germany
Refresh
ts77
(Thomas Seifert)
October 25, 2012, 4:09pm
#10
Maybe only the country db is installed / configured?
matthieu
(Matthieu Aubry)
October 26, 2012, 12:42am
#11
We will show in a next version which DB is currently found (city or country) to help troubleshoot such issues, see ticket: Improve GeoIP diagnostics · Issue #3458 · matomo-org/matomo · GitHub
