My company put me in charge of migrating our Piwik install from version 1.12 to the latest version 2.1. We are using it for a lot of websites and the database is pretty heavy (50Gb). Does some of you have some idea how long it can take to update it? I know it will depends about the server where the database is hosted but if you have some raw estimation, it will help me.
I also have another concert related to the tracking code. Is the tracking code from 1.12 will still work after migrating to 2.1?
Did you run your update by su www-data user? Or did you used a manager account? For example root?
Other question: after our update of 7GB DB (abt 27 mins.), the new 2.1.0 interface now can’t display numbers in “Frequency Overview” widget, only zero.
This happens only with data before 2014-02-23 while the database table piwik_archive_numeric_2014_02 still have all the data in it.
Thank you for these additional feedback. We are still planning but as soon as it’s done, I will come back to you with the details of the update (final database size, time to perform the update, etc.).
Well, @dali thanks you very much for helping! Don’t worry we have nightly backups of database. :)o
The problem is our log is just 45 days old (I bet was 2014-02-23 in 2014-04-11, update’s day) because we have more than a hundred of profiles with a lot of traffic.
So I suppose previous data is lost by update? I wondered that piwik_archive_numeric/blob_* tables were still untouched after doing upgrade from 1.x to 2.x. Our archive.php crontab (now console core:archive command) is run every 4 hours in a day… So logs could be deleted.
Just a quick feedback regarding this update. The update process to the version 2.2.0 has been successful. I used the console to update the database and it was quite fast as it required only 4 hours to upgrade the 54GB of data.
