Memory issue with archive
When I run the archive script I get the following error:
PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 71 bytes) in piwik1.4/core/DataTable/Row.php on line 70
Given that my piwik server is low on memory, is there a way to run the archive script for subsets of data or to somehow recover from this issue to get archiving running again?
Thanks,
Dan
It doesn’t mean your server hasn’t enough ram. The error tells you that a php script consumes more memory than it’s allowed to by configuration. Try increasing memory_limit in your php.ini. Set it to 256M for example.
