Matomo stops reporting data on dashboard
Can someone please help me find out why i am not getting any data in my reports or on the dashboard.
Do you see visits in the live visitor log?
No? Then your website is not sending data to Matomo anymore. Check for errors in the browser console, when you open your website.
Yes? Then visits are recorded properly, but reports are not generated, so please check if cron is set up and running successfully or browser archiving is enabled
I cannot see live visitors on dash board. I did look at browser console - Chrome, nothing reported. Not sure if Matomo reporting stop around the time i setup 2 step authentication.
Thoughts
Would it maybe be possible that you send me a private message with the URL to the site where Matomo is tracking?
Just send you message turned off authenication?
