Shnoulle
(Denis Chenu)
1
Looking at documentation about create a new table : https://developer.matomo.org/guides/extending-database
I just copy paste and try : but Common is not found even with \Matomo\Common\
it dion’t work.
It work replacing Matomo by Piwik , checking inclusion : all current plugins sees to use Piwik\Common\
Then it’s just to know
- Bug in manual ? Then i can make the pull request
- Manual for a develop version (but i just clone current repo)
- Another things ?
Thanks you
Lukas
(Lukas Winkler)
2
You are right, there is a bug in the docs.
I think Piwik is automatically replaced with Matomo on the pages and this is too overambitious in that case and breaks the code:
Lukas
(Lukas Winkler)
3
And thanks to @thomas_matomo great work this is already fixed.
