we tried to update Matomo(Piwik) through manual three steps update after facing so many issue and followed many articles to resolve it but now stuck in database update issue.
" Your Matomo codebase is running the old version 3.13.5 and we have detected that your Matomo Database has already been upgraded to the newer version 3.13.6. Maybe your Matomo administrators are currently finishing the upgrade process. Please try again in a few minutes. If you still have this issue please contact your Matomo administrator for assistance."
can anyone from team help me on this? also attached snapshot for same with reference links
This happened to me, run ./var/www/matomo/console --version command to make sure about what matomo version you have. i had to delete manually all matomo folder and reinstall latest version
thanks for your help deleting core folder and re-upload fixed above issue but now facing database update issue as below.
As per database initially created tables (matomo_log_visit, matomo_log_conversion) having only one âLocation_regionâ column with type char(2), when we are trying to update both tables getting below error as there is only one location region column exist but in alter command showing two columns.
Please check below issue and let us know if any more details required.
Did you already de-activate the plugin, removed the plugin from the server, downloaded the last correctly working version, installed it on the server, emptied the temp files on the server and activated the plugin again?
we have already tried removing plugin, uploading latest version and empty temp folder but can you please help me to understand? how can we de-active and re-activate plugins as we are having plugins folder under it having 76 sub folder and there no such functionality found to active and de-active plugins.
