with the update to 3.6.0 I noticed the warning that I should use force_ssl=1 but I already added assume_secure_protocol=1 since the matomo instance is running behind a nginx reverse proxy which already does the ssl handshake and thus the communication in the internal network is just http. Do I have to “live” with the warning or is there another recommendation for this scenario?
