Am i able to use matomo together with an nginx-instance.
I would like to have only 1 service behind the nginx, and let matomo count the number of visitors - not putting a js-snippet in the service.
best, i
best, i
I am not sure what exactly you mean.
You can have a look at https://matomo.org/log-analytics/ if you want to import your Nginx logs into Matomo.
Or you could use the tracking API directly to send visitor data there from your application if you want to avoid the JS-Tracking:
https://developer.matomo.org/api-reference/tracking-api
