It shows errors like:
WARNING: /plugins/CoreHome/DataTableRowAction/RowEvolution.php(266): Deprecated - Creation of dynamic property Piwik\ViewDataTable\Config::$show_series_picker is deprecated - Matomo 4.14.2 - Please report this message in the Matomo forums: (Module: CoreHome, Action: getRowEvolutionPopover, In CLI mode: false)
WARNING: /plugins/CoreHome/DataTableRowAction/RowEvolution.php(273): Deprecated - Creation of dynamic property Piwik\ViewDataTable\Config::$external_series_toggle is deprecated - Matomo 4.14.2 - Please report this message in the Matomo forums: (Module: CoreHome, Action: getRowEvolutionPopover, In CLI mode: false)
WARNING: /plugins/CoreHome/DataTableRowAction/RowEvolution.php(274): Deprecated - Creation of dynamic property Piwik\ViewDataTable\Config::$external_series_toggle_show_all is deprecated - Matomo 4.14.2 - Please report this message in the Matomo forums: (Module: CoreHome, Action: getRowEvolutionPopover, In CLI mode: false)
also core:archive generates messages like:
ERROR [2023-04-27 08:52:48] 71026 Error unserializing the following response from ?module=API&method=CoreAdminHome.archiveReports&idSite=1&period=day&date=2023-04-26&format=json&trigger=archivephp: ’ Deprecated: Using ${var} in strings is deprecated, use {$var} instead in /usr/local/www/matomo/vendor/symfony/console/Symfony/Component/Console/Helper/QuestionHelper.php on line 120 {“idarchives”:[90202],“nb_visits”:10}’
ERROR [2023-04-27 08:51:53] 70140 Error unserializing the following response from ?module=API&method=CoreAdminHome.archiveReports&idSite=3&period=day&date=2023-04-03&format=json&trigger=archivephp: ’ Deprecated: Using ${var} in strings is deprecated, use {$var} instead in /usr/local/www/matomo/vendor/symfony/console/Symfony/Component/Console/Helper/DialogHelper.php on line 52 Deprecated: Using ${var} in strings is deprecated, use {$var} instead in /usr/local/www/matomo/vendor/symfony/console/Symfony/Component/Console/Helper/QuestionHelper.php on line 120 {“idarchives”:[7324],“nb_visits”:1}’
