Hello, can you detect and short outlink and inlink by:
if site is registered for monitoring on web site (if monitored is site1.com and site2.com then fill outlink and inlink as internal trafics)
if site is registered as partner (link in phpmyvisites) have group for separate view than other incoming visitor and than other outlinks.
Thanks to improve the soft with my 2 request.
Yes I want mybe use campaigns, but I don’t found options nor docs on it.
But I want 3 view on referers -> websites:
From my website (but without js add because my web site si frequently add or removed, then I can edit the tracker on all web site)
From from my registred frendly site for trafic exchange
From other
NB: I don’t see like in phpmyvisites overall stat (statistics for all website)
NB2: It’s not serious that’s stat of one site show as outlink the same site
