Is there an option to detect also pageviews and set limitation for the particular users?
Example: 20.000 pageviews per day.
Hi @gd83caw1gd
Currently the heatmap are limited by the total number of pageviews which are stored in the given heatmap.
-> Could you please tell us more about your use case: what do you mean by 20,000 pageviews per day?
Database can collapse due to many entries. When I set limitation such as 20.000 pageviews per day it will be possible to control RAM issues, defined limitation for clients etc.
which value is set?
Quoted: the heatmap are limited by the total number of pageviews which are stored in the given heatmap
Yes, we recommend to keep the limit at 5000 as otherwise the heatmap would be too slow to generate and need too much RAM in the browser, along with other possible issues. Usually 5000 is enough to get a very deep and detailed heatmap. Thanks,
